Now I have the car roadworthy and today was to be its maiden voyage. I left my house to go to school and the car died 3km down the road. Couldn't get it started again, so I walked back to my house. Drove back down and the car started right up. I drove it back and noticed that the battery terminals were still loose, even though I had them tightened as much as I could (damn factory terminals). I swapped over the aftermarket terminals from my EGT and started to drive "the loop" (a network of roads wherein my house is located, a total of 16km). During the drive the car stalled twice and I had to let it sit a few minutes before it would start again. When it would start I heard a squeal from the belts for a couple seconds then it would go away. I checked the belts when I got home again and noticed the tell-tale black powder everywhere suggesting that the alternator is on its way out, again. *sigh*
Also, during the drive, the car bogs out frequently. With the pedal to the floor the car doesn't seem to accept any fuel and just starts slowing down. Eventually it'll pick up the throttle and away it goes. I'm not sure what is happening here, other than perhaps the fuel filter is clogged from the old rusty tank and needs to be replaced.
When I first bought the car it bogged a wee bit until I put fresh gas in it then it seemed to be okay. I drove it to my girlfriend's place, which was a 36km drive and then a couple days later I drove it to my house, which was another 35km. Both trips I didn't have any troubles with charging or bogging.
After getting to my place the alternator eventually seized and I replaced it with the one from my EGT. I've also replaced the plugs and the tank. Is my problem the fuel filter and potentially the alternator as well?
I replaced the fuel filter with the one from the parts GT, cleaned the ground wire for the fuel pump, installed a new ground wire from the engine to the chassis, and put in a spare ignition coil. I'm still having the bogging issue.
When driving the car will slow down, the revs will drop even though I have the pedal down. It will sometimes pick up and take off again and sometimes it'll stall. Tomorrow I plan on picking up a new fuel filter just to be sure.
Also, I'm running a U code VAF from the ProGT, could this be causing an issue with the B8?
