Ok guys iam doing a bp turbo swap in my dx and iam using the b8 tranny right now. what i want to know is there a good clutch and flywheel to use out there that wont slip. I have been searching on here all night a cant find what would all work good on that setup. So any help would work great.
tranny
the g is the strongest for the bp other than a toyota swap, and it is weak on a bpt. I blew my diff pin at 10 psi on a g series tranny because they can't take too much hp. 275whp is about as much as one can take with a better diff or welded diff. After that you will probably start stripping gears.Cincinnati, ohio Bengals for life
"Who Dey"
break about 4 of them.... I broke 4 at 198whp/219wtq, in about 6 months
I don't understand why all these trannies are blowing up on you guys. I have ~265whp and that is running through a 275K km old stock G-series. Stock open diff, no welded pin etc.. I have yet to blow it up. And it's been ripped on plenty. Maybe mine has been "work hardened" after being 20 years old lol..Tyler has spoken
F series clutches are smaller overall diameter and smaller input shaft diameter the clutches do not interchange
Originally posted by 92dx View Postmy f series diff blew after 3 weeks of n/a bp...
although this thread is a year old, I dont recommend an f series for anything but the sohc engine...is craptastic
5th gear swap helps you out some but not a whole lot, it's 341 rpm drop in 5th IIRC, any F2 car, 626, mx6, ford probe, I'm pretty sure all of them have it. helps some, I did it in 1 hour just so I didn't spin the engine up so high on the highway all the time! and it gave me about 2 mpg or so.
