Hey guys,
I own a festiva with a EGT BP engine swapped into it. I have had some problems with sputtering and hesitation when i punch the gas pedal. If I ease onto the gas the car will not sputter and pull to red line. However, if I smash the gas pedal the car will sputter. The car will run great when i first start it up and then all at once the car will kick the idle up (~1300 rpm) and it will sputter. The car has also flooded and I believe it is running rich because you can smell the gas in the exhaust (and it also floods). I tried to pull codes from the car, but nothing is coming up. I am not good with fuel systems and I want to try to narrow down the problem before I go replacing fuel system components with expensive parts.
My car has (copy and pasted):The stock 63 HP, 1.3 liter engine has been removed and replaced with a 150 HP, built, Escort GT engine. That's a 1.8 liter engine, with about 130 HP stock... Take that and add Wiseco 10.5 to 1 pistons, bored 40 over, headwork, crank turning and balancing, lightening flywheel and machined for a Suzuki Swift stage 4 clutch, Toda adjustable cam gears, Escort "exhintake" cam swap, Pacesetter headers, 2.25" full exhaust, Walbro 255 performance fuel pump, UR crank pulley and more... Then add a bunch of weight reduction, lowered on FMS springs, Billstein front and KYB Super rear struts, Aspire "big brake" upgrade, rolling on 15" wheels wrapped in 195/45 Toyo Proxies...
Any ideas? I just bought the car and the previous owner told me a fuel pressure regulator, but I do not know. The car runs the same with or without the vacuum hooked to the regulator and no gas in the vacuum lines.....
Sorry if this is the wrong forum to post in, this is my first time on this site.
Thanks!
Thanks!
