LOOK I BEEN DEALING WITH THIS MYSTERIOUS MISS FIRE I CANt FIGURE out I CHECKED THE PLUGS SOMEBODY told me the plugs could of been gaped wrong but i dnt think so what does seem to you the injectors or fuel when you touch the gas the motor bogs out help???????????????
what do you guys think
dont you love hondas cute little toys:
my girlfriend says i spend to much time with my car sorry its true Mazda girl get jealousTags: None
Here is a hint:
Even if your a n00b who can't search
TURN OFF THE CAPSLOCK AND TYPE COHERENT SENTENCES!"Discontent is the first necessity of progress."
i can search how this you work 15 hours and then have your car keep screwing up god cut me a break if your no gunna help me your comment is unnecessary and smart one im dyslexic
No need to get nasty especially when you were given good advice. Even if you're dyslexic you can still do a search to help narrow down the problem and allow you to ask more relevant questions that are more likely to give you the answers you need.
How do you look a a fuel filter to see if its good still??? Slap a new one in there if you have no idea when the last one was installed. Less than 20 for a new one.
Might be a bad vaf as well1993 Protege LX-Midnight's shadow SOLD
Misfires can be caused by numerous things. I would check your cap and rotor, usually plugs don't cause a misfire unless there is something seriously wrong with them. It could be your timing or throttle position sensor as well. Like I said there are numerous causes of bogging and missing.. My car does it randomly in 1st gear.. I still haven't figured it out after months of trying.
