Well here is the issue i'm having...
Last weekend me and my brother swapped an engine in my 323, we installed one from a 90 Protege 1.8 SOHC. We also installed an ECU from a 90 Pro (BP47). I started the engine with no exhaust manifold and it kept dying after few seconds, Then we realized the ground wire from the engine was not connected and it started smoking. Next day I picked up a manifold and installed it with an O2 sensor. The car started right up and i let it run for about 15 minutes. I repeated it about 4 times and there were no issues. Next day however I went to start the car up, and NOTHING. The engine turns, eventually starts and then dies after few seconds ( dies even quicker when I press the gas pedal). I have a 93 323 sitting in my driveway, and I took MAF out of it and that still did not help. I did notice the fuel pump relay makes a loud ticking sound ( is that normal). Could that ground wire that was not connected damage something? (again the car ran good after that for some time) Will the fuel pump relay from 93 323 work with this ECU? All vacuum lines look fine, unless we connected them wrong...I still have a lot of parts on the engine that I took out, not sure if all of them will work. Please help me
