Warning, super rambling.
So I've been plagued with this through 3 different Escort Gt's and a BP Tracer. Even with half the radiator blocked off (FWD BP's are cold runnning whores.) I tried flushing the heater cores and running that flushing agent you can get at auto parts stores, all to no avail. I never seem to hear about others with this problem but know someone else has to have had the issue. I think I finally found a solution.
Basically there is a clog and flushing agents and flushing just the heater core won't get it. The clog is in the sandwich oil cooler on the block. The coolant to the heater core goes through the oil cooler first. If there is a clog in the cooler it doesn't matter how clean the rest of the, heater core/ block/ radiator/ lines are.
I wound up going to the hardware strore and buying a 5/8inch male barbed fitting/female garden hose end. It was $4. This plugs right into the heater hoses and with a clamp will only blow off if there is a major clog(which mine had.)
I just took off the intake, then took off the two heater core hoses right on the side of the head over the trans. Aimed one at the ground and one plugged into the garden hose. Flush one way then the other. After I blew the hose off in my engine bay I had to work up the pressure untill the clog was gone. It took a solid 2 minutes of full garden hose pressure untill the cooler ran clean.
My heat rocked immediatly. I flushed the whole system 4 times for good measure. Hopefully I and someone else won't have such a miserable winter.
