I have tried searching over and over and cant find a solution to my problem the hose that goes to my intake form my valve cover broke so i bought a mini breather but it still smokes how do i get it to not smoke i tightened so i know its tight so what are some suggestions
mini breather
its smoking from the breather? good chances are you're running real hot, what's your ignition timing set to?
also did you plug the hole in the intake pipe? if not, that'll cause an issue since the leak is between the throttle and the air meter...-Jack
How do i plug the whole in the intake pipe it didnt know that had to be done and the other reason i think its not the running hot issue is because it happens as soon as it starts up
dont you love hondas cute little toys:
my girlfriend says i spend to much time with my car sorry its true Mazda girl get jealous
do you guys think if i left that little plastic thing that runs the hos back in to t he intake hose uncovered it could cuz this uncovered it could make ht e little filter smoke
