Hey guys i've been looking for a shift shaft seal that will work in my 94 protege sohc manual tranny, and i found a part number on rockauto for a timken part # 221620. So i called autozone and they had this one in stock, and I went to look at it, but its a bit bigger in diameter and doesn't look like it would fit. Also it doesn't have the metal looking part attached to it that the rubber boot from the change rod goes over it. I also did a search on here, but not sure if any of the stuff would work with the sohc tranny.
Shift Shaft Seal
