Need a sanity check here guys, so please chime in if you can.
Engine cranks but will not start. Sprayed starter fluid into the vacuum box and engine started and ran for a while.
I have verified that there is fuel pressure, that all 4 injectors fire fuel, and that there is nothing wrong with the rest of the wires/components in the injector circuit.
Is there any other reason for this "run with starter fluid" behavior other then the ECU being bad???? Someone PLEASE save me from spending the bucks for another ECU when the problem lies elsewhere.
