New thread, other one had gotten to confused.... This is in response to CC scope post.
"Its from a 92 mazda protege 1.8L SOHC No cam signal but you can see #1 injector in relation to crank signal and ignition primary... This is at idle..."
no NE is not a problem, as it tracks with ignitor signal, so we can just pretend that is NE.
It does not look like there is a G signal either (which would be 1 pulse every 4 ignitor pulses (or NE pulses)).
Your "CKP sensor" does NOT seem (to me) to be a crank shaft position signal... the pulses match up with the ignitor, and so I would have to conclude they are actually the distributor NE signal. I dont know how I could be wrong on this, but please let me know if I am.
Examining the CKP(NE) and injector 1 traces it appears to me that
1) either the firing order or the injector paring for your BP and my BPT are NOT the same. Mine is 1342 with 1/3 and 2/4.
2) your BP is firing its 1/? injector twice in a single cam rotation (which is what I needed to know.... and is very bad news.)
"When I look closely at your pictures it almost looks like the scope is trying to pic something up but isn't drawing it... It'll be in the same place as the second injector fire in my image when you are looking at your NE/injector 1 picture..."
I dont think that is where it is. If you look at
you will see the same blips and also see that the are coincident with the other injector pare firing.... my take the blip's are the suppression of an injector pulse that would occur if the ECU was in open-loop (limp) mode. From the firing order (1342) and the injector pairing (1/3 and 2/4) I should be getting:
1/3: X X - -
2/4: - - X X
instead I am getting
1/3: X----
2/4: --X-
I really need a trace from a BPT (BP26 or BPC08 ecu), but your BP makes it look like I am screwed... but there is enough very basic differences between your BP and my BPT (very surprising that firing order/injector pairing is different - are you sure thats a BP?) that I still am not sure my ECU has a problem.
1/3: X X - -
2/4: - - X X
1/3: X----
2/4: --X-
