i asked this already and people said its the rod bearing but i think its the lifters i took the engine out put it on a stand and notice my fly wheel bolst were lose like really loose and it moved up and down since i used bolt tight green which makes sense why it sounds like death... now the rods r tight and compared to what i seen before when rod knock occurs there is no play i cant move them at all also my oil pick up was full of mud like sludge and i pulled 8.3 oz of sludge from the bottom of the pan which could be why the lifters werent getting enough oil... how do i know if i have rod knock now that the engine is out on a stand....
engine on stand how to check for rod knock?
i asked this already and people said its the rod bearing but i think its the lifters i took the engine out put it on a stand and notice my fly wheel bolst were lose like really loose and it moved up and down since i used bolt tight green which makes sense why it sounds like death... now the rods r tight and compared to what i seen before when rod knock occurs there is no play i cant move them at all also my oil pick up was full of mud like sludge and i pulled 8.3 oz of sludge from the bottom of the pan which could be why the lifters werent getting enough oil... how do i know if i have rod knock now that the engine is out on a stand....Tags: None
wow that's a horrible noise lol, doesn't sound like rod knock to me thought...it's usually a hollow deep noise. I say if you found loose flywheel bolts, you found your culprit.
The only way to spec out the rods/pistons/bearings is to disassemble and use the proper tools to check clearances. Generally rod knock will have some visible wear on the piston skirts tho, or you would see a damaged/spun bearing.-Jack
01 E53 3.0i - FOR SALE!
pm if interested
i bought a probe like 8 years ago that had a freshly rebuilt motor with a supposed rod knock. and it ended up being exactly what you said. i yanked the motor. and the flywheel bolts were only hand tightened. and the flywheel was getting knocked around. motor ended up being fine. so it does def happen!
~PaTricK~
-Current car's-
What are you driving?
i had one sound like this with a stretched t belt slapping around. take a peek there as well.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
