Ok guys, thanks for your help so for. Three questions:
1. Is the wastegate solenoid needed? I feel it's only there to ensure you don't exceed 7psi. I'm planning to run an mbc set for 12-14psi.
2. The Fpr solenoid, is it needed? I don't believe I have one, can I substitute a solenoid off of the bp05? From my understanding it helps with hot starting?
3. Check valve for purge control, what's a good source for those? I was thinking te check valve that came off the cruise control might work. What all have you guys done?
Any other tips?
Thanks!
Any other tips?
Thanks!
