like the title states, there is oil in my antifreeze but the engine oil looks perfectly fine.
A little background.... the last few weeks I have been putting tons of oil in the car (like a quart every 300 miles), but it is not smoking very bad and it runs excellent! I was thinking I should consider a rebuild pretty soon because of the oil consumption, but I think I have other problems. I am not sure how the oil is getting in there, here is my assumptions...
I don’t think the head gasket is bad since the oil looks fine.
I put a VF12/VJ20 hybrid turbo on it last year and rebuilt the center section myself and ran the oil and coolant through it, do you think that the oil is getting pushed into the coolant in the turbo center section??
another thing I was considering was the head studs, they are stock. maybe the stock studs are not strong enough for this turbo at full boost and the head is lifting up and forcing the oil into the coolant jackets??
what do you guys think? I'm going to go and drain the coolant and take out the rad now, if I find something I'll keep you updated.... but other than that, any thoughts about my situation would be greatly appreciated.
Thanks,
Chris
Thanks,
Chris
