93 protege what is code 41 what do I replace or check where is it on car what does it look like I know its intake manifold air control solenoid what is this???
41 is VICS solenoid. passenger side of the intake manifold there will be 2 solenoids on a bracket . 1 attached with vaccume lines to the fuel pressure regulator the other to a small canister on the manifold that leads to the dash-pot on the manifold that opens the vics butterflies inside the manifold. check for it being unplugged OR broken vac lines
Originally posted by MazdaNoob View Postand limit your question to one thread please .. i am not going to hop all over to answer you
no you are diluting the information . the purpose is to post an issue and a resolve in a searchable fashion so that others can find the solution as well. by posting all over the forum people are less likely to post a resolve in ALL your threads.
it is located towards the intake manifold side of the distributor . and no .. it is not the same sensor that your temp gauge uses
