Hey guys, so every once in a while my clutch feels like it looses hydraulic power, I'll pump it a couple times n then it's fine. It seems to happen when I take it up to 5 or 6 grand rpms. Any ideas,? Break fluid is full.
clutch issue?
clutch issue?
97 Z28 Camaro 5.7 LT1,
K&N CAI,
3' Exhaust W/Hooker muffler
160' Hypertech thermostat
TB water delete
4.10 motive gears
Powerstop drilled n slotted rotors n pads
Z06 rims
92 Protege Lx, Bp -
Custom cold air intake
Gready exhaust
Front and rear strut bars
5% tint
Pear blue calipers
Flat black 7 spoke alloy rims
KYB GR-2 shocks
Eibach Pro Lowering springs
Brembo rotors, ceramic pads
93 Z28 Camaro - very sadly totalled
94 RX-7 turbo.- Sadly Sold
95 CRX Honda - Sold
98 Kai Sophia - Sold
04 SV650sv Suzuki - Sold behind my back
85 Camaro Rs - first car SoldTags: None
Bump.. anythin guys? Nobodys had this happen?97 Z28 Camaro 5.7 LT1,
K&N CAI,
TB water delete
4.10 motive gears
Z06 rims
92 Protege Lx, Bp -
Gready exhaust
5% tint
Pear blue calipers
KYB GR-2 shocks
95 CRX Honda - Sold
Sounds like you have a problem with he clutch master or slave cup. Id look knot replacing the slave cyl first. That's usually the problem. Also might want to look into the rubber clutch line that runs between both. It's an old car.1993 Protege LX-Midnight's shadow SOLD
yep, probably clutch master.
Inside the car, follow the clutch pedal up til you see a long push rod. The push rod activates the clutch master piston, pushing it forwards. Check around for any signs of moisture as they often leak in the car, not in the engine bay.
I have also had issues with the fluid sharing from the brake master cylinders reservoir as well. Where the hose seals into the clutch master it was allowing air to enter causing bubbles, then eventually started leaking on me.-Jack
Cool ill give that a check, thanks for the info guys, ill let ya kno what i find.97 Z28 Camaro 5.7 LT1,
K&N CAI,
TB water delete
4.10 motive gears
Z06 rims
92 Protege Lx, Bp -
Gready exhaust
5% tint
Pear blue calipers
KYB GR-2 shocks
95 CRX Honda - Sold
yep, master. if pressure comes back after pumpin it it's usually that. Slave is more obvious, what with the inevitable leak. When the master goes it can just recirc the fluid round the piston and not leak at all.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
