I replaced the flywheel with a larger GTX Flywheel. It seems my slave doesn't come out far enough, seems too short. I'm also having a difficult time getting it in to 1st gear. Is the slave different on a Grx?
GTX Slave cylinder
GTX Slave cylinder
91 GT- Li'l Bee (under construction)
2013 Honda Accord V6 coupe - 14.7 sec. 1/4 mile
New Thread:
Wilyb's 91 Pro GT Rebuild: Li'l B: http://www.clubprotege.com/forum/sho...Rebuild-Li-l-B
Old Threads:
WilyB's 93 GT rebuild worklog : http://www.clubprotege.com/forum/sho...-93-GT-rebuild
My FE3 worklog thread:http://www.clubprotege.com/forum/sho...ighlight=wilyb
sigpicTags: None
How the pedal free play?92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
there has been instances where i've welded 2 of the slave cylinder piston rods together & ground it down where it was properly contacting again.... my pedal feel is spot on now---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I never disconnected the slave, so there should still be no air in it...but when I put it back on I had to get someone to pump the clutch twice before it pushed the fork. And it looked hyper extended...I'll need to take a closer look...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
The only way it'd come out too far is if it broke the seal and popped out lol. Probably have to adjust your clutch pedal, grab a 12mm and a 10mm wrench and look at the clutch pedal, should only be about 1/2" of pedal free play as well iirc.-Jack
Actually less then that, FSM spec is around 1/4" or less.92 Mazda MX3 GS> For sale, $1750 OBO
slick!-Jack
