I just install a Microtech on my 94 Protege and this gauge is not working anybody can tell me how to make it work again without the stock ecu?
Need help with fuel level gauge
Nothing to do with ECU. Visually inspect the sender.1990 Protege 4WD
1 3 5
2 4 R
Correct, the sender is not connected to the ecu at all. From the FSM, the black/green wire should be grounded and the yellow wire goes to the cluster. The sender is just a variable resistor with a pull-up in the cluster.
There will be power for the pump, obviously, but not for the sender.1990 Protege 4WD
1 3 5
2 4 R
