Hi everyone. I have been researching this topic for a few days and found some answers, and also had a few more questions in the process as well. I have the BP DOHC engine from a 91 LX and due to poor compression, I want to rebuild it. I want to put some good pistons and rods in place so I can eventually tune it for performance. From my research I have found that Wiseco seems to be the favorite here as well as Eagle rods. I also found mention of FlyinMiata's custom parts but those are very much out of my price range.
After some searching I have found what appears to be a pretty good deal on Wiseco pistons and Eagle rods: http://www.ebay.com/itm/270771668724...84.m1423.l2649
My questions are:
- Will I have any problems with the stock piston oil squirters? (Some forum searches said yes, some said no)
- Will this change the engine to be an interference design? (Possibility of valves making contact with piston)
Also for later upgrade options, I have the following questions:
- How can I increase the engine performance without using some form of boost. (Cams, intake, exhaust?)
- What kind of performance numbers can I safely expect without boosting?
- What are recommended manufacturers/parts for headers/exhaust upgrades?
I realize these are a lot of questions but the more I research, the more questions I have and if I am going to go down this path, I don't want to use any substandard or dangerous parts and ruin my engine block or waste my time and money. Thank you all for your help.
My questions are:
