Turbo IHI RHF6 VJ23
    Turbo IHI RHF6 VJ23
    Hi!!
    My Mazda 323 GTR Turbo has broken.. And it cannot be repaired..
    Do you know which is the best turbo to substitute the original one?
    I need to buy one and i don't know which is the best for it..
    Thanks in advance!
    Raúl
    Your VJ23 has a specific manifold flange. Like I told you before, you would need to have an adapter made for your manifold to accept any other turbo, whether it be a T25 or a T3 flange. or move to a custom exhaust manifold. You are best now looking for another VJ23 or have yours rebuilt.
      I got one I could sell you
      1988 BF GTX
      1990 x2 BG AWD Protege
      1991 Escort GT- SOLD
      2005 Corolla
        Originally posted by azgtx View Post
        ...have yours rebuilt.
        I didn't think that was possible. What exactly do you mean by rebuilt?
        1990 Protege 4WD
        1 3 5
        2 4 R
          I keep hearing rumors as to how some shop out there can put the turbine housings on a garrett cartridge, never seen such a thing myself.
            Wasnt Ferdi trying to do a GB for adapter flanges? This would be the easiest solution.
            FS Forged H beam rods
            awaiting test fit
            Aluminum CAS/Distributor caps
            BP oil jet eliminators
            EV14 fuel rail spacers
            More stuff coming soon.......
              I had a machine shop make 2 for me. I went back there to see would they make some more and they said hayell nooo....
                need to find the shop that made the Cork Sport hybrids. Those were well done.
                  Turbo IHI RHF6 VJ23
                  Talked to Derrick today from cork sport. He has been there for a long time. He said they used Alamo turbo in Kent Washington. I called them and recalled building them but said they where no longer building stuff like that. Not enough demand for them
                    whats the problem with your turbo? oil consumption, shaft play, bearing noise?
                    i ask because i recently had to swap mine because of an oil leak on the exhaust side and also bearing sounds.
