Is there anyone on here that has put a newer engine with vvt in an obd1 car? I found a really good deal on a bp z3(I think) out of a 02 mx5. It comes with all sensors and at least partial harness. Anyone have experience and know the best way to deal with ecu and wiring?
vvt engine in first gen protege help
I am doing something similar to you but with an engine from a Mazda 3. I am using the 3 harness and ECU though.
For a Miata setup, there is the highly supported Megasquirt option or this:
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
The distributor and intake manifold are not a direct fit.
Check here:
I would leave the VVT alone. Its a good thing for a street car.92 Mazda MX3 GS> For sale, $1750 OBO
You'll want to be abe to control it, that's sorta the whole point of it. Stock controller or standalone, whatever works. Next up, just to go with vvt, converting stock bp head to direct injection. Oh how I wish... man we'd bust gearboxes in a heartbeat.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Do a google search for specifics but I believe your losing low/midrange by disabling it. Also the head and cam are VVT specific so you cant just swap cams to disable it.92 Mazda MX3 GS> For sale, $1750 OBO
Had some free time today so I started taking off exhaust an intake manifold, ac pump, ps pump.
Took off the valve cover to see how it looked inside, have to say it looks good! When I got it the guy said it had under 70,000. I was worried about it sitting for (who knows how long). But it turns over easy and look like low miles. I've never worked on a used engine that wasn't at least a little stained.
Here is a pic of the mx5 gasget on the 94 pro intake so you can see the modifications that need to be done, the pattern s exactly the same just higher ports so the holes need moved down.
In the other pic is the 94 pro distributor in the mx5 head. Thank you mazda for being lazy lol. The head is missing the outer hole for the distributor. But I'm thinking it will be fine with one.
Got the lower intake cut and new holes drilled to move it up. Not sure what I'm goin to do about the bottom bolts tho. Not sure if I wanna cut off the bottom and weld on a piece of aluminum like the other ones I've seen on here.
I also spliced the harness together for the injectors and vics and the other solenoid.
One thing to note for anyone doin this swap, the purple injectors are to tall for the fuel rail off the older bp. And the fuel rail that comes on the bp z3 has fuel inlet on front of engine and there is no return line. Not sure how it works on the mx5. I'm just goin to make a custom piece off the rail with a hose barb and just use a adjustable pressure regulator for tunning.
