Hey guys did anyone ever have the problem of running a too strong clutch that would cause the thrust washers to completely wear and make the crank walk? this is what I think happened to mine. Im running a SPEC stage 3+ clutch and lightened fidanza flywheel
Clutch/Thrust washer Problem
I've worried about it, but never had it happen. What's it doing that made you look for crank walk and how much are we talkin here?'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
ive seen it in person. but the driver was heavily abusive with it.... and it wasnt' on a spec 3+(which isn't really aggressive anyway- or heavily weighted)
he was running a clutch net unit. id say this was probably early 2000. so my memory is fuzzy. but never the less its uncommon unless your pressure plate is retardedly overkill & you drive like a jackass---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by jay View PostI've worried about it, but never had it happen. What's it doing that made you look for crank walk and how much are we talkin here?
Originally posted by FE3-323 View Postive seen it in person. but the driver was heavily abusive with it.... and it wasnt' on a spec 3+(which isn't really aggressive anyway- or heavily weighted)
