90 LX, 140K. Been loosing coolant for a few months now. Zero leaks. Adding water, so I'm now 100% water. Currently loosing a quart every 40 miles, one way to work. Took out the thermostat to do a flush before using a head gasket chemical (really not worth tearing into) and its still loosing coolant, and runs just as hot as with a thermostat. Still not 100% sure it's a head gasket. No white vapor exiting the exhaust, or drippage at the tailpipe. Compression test readings were 154, 147, 140, 147. Is that enough of a variance to assume the head gasket?
Thanks in advance for any beneficial input.
