lwihdugkn diedwqh
7 to 8 G's
Originally posted by atomicEGT View Post[ATTACH=CONFIG]69206[/ATTACH]
Sent from my iPhone using Tapatalk92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Did you replace the thermostate. I see a list of stuff that doesn't make sense. You have changed the head gasket but has the thermostate been done? Did you bleed the cooling system properly?91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
all that bull**** and no mention of anything in the cooling system despite it being an overheating problem. did you bother checking the head to make sure it was straight and not cracked before putting a new gasket in? replace the water pump when you did the timing belt? there is so much here that doesn't add up. a stock ECU ain't gonna let you see 8k unless you do something stupid, and even then, the only way I can see an over-rev causing a cooling issue is if it caused the water pump to cavitate and you held it there like a moron... except this isn't an SR20, so the odds are against that.
tl;dr sell itsigpic
Wtf did i miss?1995 escort wagon gtr/holset
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
