I Just ordered a Centerforce clutch and Pressure Plate from nopi.com but i forgot to order the Throw Out Bearing. Do I really need the Centerforce one, or can I use my stock bearing.?
Thanks !
if you have an automatic you dont have a throw out bearing, you have a torque converter.
you'll need to order one. did you remember to order a pilot bearing and a pressure plate?
Uhh.. If I ordered a Centerforce clutch and a Pressure plate, then i guess that means I obiously have a manual tranny, Now. Remember me ? Im the guy thats doing the auto to manual conversion.
What I meant was.. :shrug: I ordered a Centerforce clutch and Pressure plate... Do I also need the Centerforce Throw out bearing and pilot bearing, or can I use my stock throw out and pilot bearings(the ones that came with the tranny)
Past: 1994 White Protege DX ~DEAD~
Current:05' Onyx Black Mazda 6 'S' ~Bone Stock~
Originally posted by TheMAN
you MUST keep in mind the 2nd gen is the bastard child of the proteges...
sorry by reading your signature i though you were in the middle of a auto to manual conversion. you dont need center forces pilot bearing and TOB, one from pepboys would do just fine.
i received my centerforce dual friction 2 days ago and noticed that the clutch disc is exedy. Is urs exedy too ? I know the press. plate is centerforce but not the disc.
To answer ur question... The centeforce clutch dont come with alignment tool and throwout bearing. Reason y is because the stock tool and bearing can be used on the centerforce kit.
Do not use ur old throw out bearing just get a new one at the dealer or kragen for less than $30...
I dont' remember if mine is exedy.. and it's too late to look at it and to put a throw out bearing because i already put the tranny back in.. so..
I think it was said that Centerforce designs the clutches, but they send the designs to exedy... it was an arrangement like that. Just remember seeing that on here somewhere....
