My alternator went out last night at 6 so I went to autozone a bought a new one before I could go to work... I had to get one of my buddys to take me to work and I would nite shifts sweepin parking lots... I went in at 8pm and didnt get off intell 9am so im tried and I want to put the new damn alternator on so anyhelp would be good.... Here are some pics ,,, I took the two bolt from the top out how much more do I have to do....
Alternator is gone...
I see no pics????
If you removed the two bolts already, then it's a matter of sliding off the old alternator and putting the new one in. Make sure you tighten the belt pretty good once the alternator swap is complete.-------------------------
'91 LX
'03 Mazdaspeed Protege #235
start the car then turn it off then try again. if it starts then ur altenatoer works if it dosent start then it dont workLast edited by skr33t_rac3r; 05-06-2004, 10:04 PM.i is dumb
Originally posted by skr33t_rac3rstart the car then turn it off then try again. if it starts then ur altenatoer works if it dosent start then it dont work
There is a way to check to see if your altenator is charging correctly. I didn't read it in the FSM, but I know it is in the manual. You can also take the car to autozone and they can use a machine to test it.
everytime i turn on my ac and hit the gas my belt squeal real loud and it goes away now it squeal all the time I hit the gas with the ac on and if I havent started up my car in a day it squeals with no ac on too what the hell is that the belts look good... Im really gettin sick of that stupied ass noise....Ratrod
