well my shifter's been really loose since I purchased about 1 yr and 1/2 ago, dunno if thats part of the problem. Here's my jiff I cannot seem to shift to any gear and my clutch pedal has gotten a little soft<--this happens about 50 % of my driving time the other 50 % the car works fine dunno wtf .when this problem happens I jam the stick into 3rd and drive the rest of my journey on 3rd. my car is currenty on front of my house I cannot shift to any gear at all. Any know what this could be???please help me! thanx
Cant' Shift!!
bleed your clutchWhen you turn your car on... does it return the favor?
Originally posted by goldstarYes, still have it. It was my attempt to immortalize you in verse.
A Protege driver named Brock
So his engine he goosed
With much too much boost,
Originally posted by Protossbleed your clutch
good luck91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
thanx for your replys. I've noticed I've been leaking clutch/brake fluid from the clutch release cylinder for some time . I filled the fluid reservoir but fluid keeps leaking from the boot that covers the push rod . I think it might be time to head over to the mazda dealer/ junkyard for a new part.94 LX
try to tighten it first b4 you go spending money....91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
