Yes, I have done this mod. It's an old idea. The factory manual pretty much covers this.
I have never mentioned anything about idle. You confused my with someone else, I think.
I'm sorry about the "built" thing. I thought that the term was common enough everywhere.
The stock fuel pressure: Between 30 and 37 psi with engine idling and the hose connected. Between 38 to 46 psi with engine idling and hose disconnected, according to my manual.
The FPR increases the pressure in the rail as a function of decreasing vacuum. It is there to make sure that there is enough fuel available to the injectors under all loads without needing to change the rate of the fuel pump itself. It is a restrictor in the return path of the fuel back to the tank. (I'm sure you knew all this already )
The factory manual explains that pulling the hose should raise the fuel pressure in the rail to between 38 to 46 psi. It also explains that this is the pressure you should get at full throttle. This is why they have the procedure to test the regulator with the pulled hose.
This is what I have done myself: I have hooked up a fuel gauge and measured fuel pressure at idle and then at full open throttle. I have then diconnected the hose at the FPR. The result: The same pressure that I saw at full throttle is what I saw immediately at the FPR when I pulled the hose. No matter what the throttle position was. I am sorry that I don't have the exact psi numbers of that particular test with me, but I have them in the race car's logbook and I it is with the car, which is not at my house. That is all I can bring to the table as far as this discussion.
Anyway, look; I don't mean to offend you and I appologize if I was too enthusiastic in my responses. You should go ahead and try it yourself. It should be pretty easy to prove by hooking up a fuel gauge with a "T" to the fuel line. If you find that you are getting more pressure with the pulled hose than you get with it connected and the throttle wide open let me know because then I will be very confused as to why that would be the case and I am always interested in learning. I never have any problem admiting that I am wrong when I am. So, let me know, OK?
:D
:D
