Very interesting/surprising results!
Same basic setup as last time: 224K mile original motor, 87 octane, 14 degree timing all runs listed. outside temp ~8 degrees cooler than last time...
2) baseline with intake cam -1, exhaust cam 0:
116.5 whp/ 107.1 ftlbs
the torque *peak* is misleading: i gained 10 ftlbs below torque peak!!(i'll be more specific below)
3) intake cam(INT) 0, exhaust cam(EXH) 0:
117.6 whp/ 108.8 ftlbs
5) *** INT +2, EXH 0: ***
*** 117.3 whp/ 110.5 ftlbs ***
w/RX7 VAF richened 2 clicks:
*** 118.3 whp/ 111.1 ft lbs ***
now comparing this to my best previous peak torque with the stock INT +4, EXH 0 (116.1 whp/ 108.7ftlbs), i gained ~15 ftlbs @ 2600 and 3000rpm!! from 3250 to 4500 the gains gradually taper from +5ftlbs gain to +3ftlbs @ 4500. fat torque gains to 4700rpm where the stock cams finally (nearly) match the regrinds. peak gains 2hp as well.
9) INT -2, EXH 0:
119.8 whp/ 109.8 ftlbs
10) *** INT -3, EXH 0: ***
*** 120.6 whp/ 109.8 ftlbs ***
*** 121.1 whp/ 109.9 ftlbs ***
comparing this to the best previous peak hp (WHEN retarding the INT...) with the stock INT -4, EXH 0 (116.0 whp/ 108.5 ftlbs), i gained 5 whp @ 6650 rpm with the gains growing all the way from 5400 to redline! @ 5700 the regrinds begin making about +3whp over the stock cams. there are torque gains as well with +13ftlbs @ 2750 to 3000rpm. +4ftlbs from 3700 to 4000.
those are the best of the runs - spent 2hrs on the dynojet doing 20 4th gear pulls.
basically i went from 0 to +6 and 0 to -6 in 1 degree increments on the intake cam. once i found the 2 best settings noted above ( #5 and #10), i then adjusted the RX7 VAF. interestingly enough both of those cam settings liked it 2 clicks richer over the original setting with the stock cams.
the last run #20 i set the INT +2, EXH -2 (ignition set to 14):
118.8 whp/ 110.5 ftlbs
what's interesting about this last run is how ABSOLUTELY SMOOTH the power is! in other words, NO 'choppiness' - like some of the other runs tend to have... the motor had been thoroughly wrung out by then too.
9) INT -2, EXH 0:
