I might be wrong but why does a damn headlight buzzer matter?
Headlight buzzer / intermitent wipers
mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by bwilderedSo months later I remember to finally get the buzzer.. I get home to install it and I found out on the back of the fuse box is a white box already there. So now the question is....
1. Is that part for something else other than the buzzer? There are two different part number, BR70 and BR71, if I recall correctly.
2. Maybe my existing part is bad?
3. Or maybe somebody disconnected something to stop the buzzing?
Thanks,
Don
I replaced mine with an LX one and no problems so far.1994 Mazda Protege DX
2005 Saab 9-2x Aero
Originally posted by davidmw1Are those boxes available at parts stores or dealer items?
Could this part be bad, and cause the false belt warning from the console belts?
The junk yard would probably be your best route.
If your seatbelt light keeps coming on, it's most likely a worn out seat belt sensor. It is a common problem, and there is an easy fix:
Originally posted by Silentbob343some of us are retarded and leave the lights on.
c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Originally posted by JhoGotta keep those things strapped tight Corky.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
