ok, today i know 100% my running lights and low beams were working, went to the movies, and when we were leaving, they didn;t work, not even my high beams, so i go and look under the hood and the fuse was blowin, so i changed it and it still didn;t work, so i could only use high beams (low and running didn't work)
so i get home and the low and running are working, so i get out to look and they fade out and the fuse is blowin again
ok so i installed two 4" led's on each side, but there all wired up for a direct wire up, could that be the problem? but there set up fo the wires just go to ground, brake and signal, so it's easy wire up and they work perfect and no blowin taillight fuse just the headlight one, and it's warm, but thought maybe it's because i was running high beams for 20-25 min's
they have worked fine up until tonight, and i just instealled the taillights today, but worked all day no problem, wasn;t sure if it was blowin until someone flashed me, and i looked and said i don't think i have headlights, pulled over and nope.
so i am going to try and cheak all the conections, should be fine tho. maybe try a bigger fuse from a 30 to a (35 or 40) and try a new headlights relay.
i am also going to put the old tailights back in and if thats the problem, maybe try a relay on the taillights.
any ideas guys.
JustinGT
any ideas guys.
JustinGT
