well its not really a big problem but i just put my mirage halos in and they are super sick but i got a prob i wired everything up but when i switch on my highs it just switches rings instead of all four lighting it goes from the two inners(lows) to the two outers(highs) does any one know why its doing this? also is there a way to get that h.i.d. lighting look with these or is it that just normal white look cause i really want that h.i.d. look thanks guys
big problem
Any luck dude? there's a how to somewhere here i think, just seach, should give you the wiring schematic for that.
Good luck and post pics!
JACK.
Jho, what HID kits are you talking about?-Jack
Originally posted by protegeguy View Postpreciate it jo
Originally posted by Mazda_Powered View PostJho, what HID kits are you talking about?
I sounds like you have the halos wired to the head lights. and the headlights not wired. so when you turn the switch to headlights, only the rings come on. Try hard wiring the halos to the side marker lights but make sure you don't wire it to the blinker wire. Than wire the bulbs to the original headlights.Too bad I have AWD and you don't!
Originally posted by 92_2_fast View PostI sounds like you have the halos wired to the head lights. and the headlights not wired. so when you turn the switch to headlights, only the rings come on. Try hard wiring the halos to the side marker lights but make sure you don't wire it to the blinker wire. Than wire the bulbs to the original headlights.
IF you are trying to get BOTH low beams AND high beams to come on when the HIGHS are selected, you will have to use a relay to send power to the lows when you switch the highs on...My 93 chevy truck NEEDED that modification...talk about a difference in lighting! Basically, you wire the relay so that when the high beams get power, it turns on, and sends power to the lows as well. People sell kits from $20-50, but all it takes is a standard (JY!) bosch style relay. If this does not describe your problem, let me know.Prior Pro owner RIP 1992/94 DX $1 Hybrid
Currently
1993 Escort LX 1.9 SOHC (yes, slow, I know)
MX3 TTL's/swaybar
MX3 LCA's (installed now!)
$2.13 Lowes shifter bushings
ES Poly bushings (Swaybars, rear LCA, Front LCA's)
Tracer corners
Escort 15s w/ 205/50-15s
Oh, ok I see what your saying, I think... So all the lights are functioning like they are supposed to? The Halo's are working all the time, the lows are on when you turn them on and the halos are still on, than when you switch to high beams, the lows go off w/ halos on and the brights come on. Is this what's happening? If that is the case than thats just how lights work. Like mightyfreecar said, you can wire in a reley to turn them both on.
EDIT: I agree. I'm tired of people coming on and being dicks about what people are doing to their cars. Personally I try to help where ever my experience can. I'm not going to sit there and tell someone they're gay even if I don't like what they're doing. Hell if you want to know how to wire in an electric supercharger, hell I'll tell you, but I think their dumb. I say people either be helpfull or shut the **** up.Last edited by 92_2_fast; 11-12-2006, 10:51 AM.Too bad I have AWD and you don't!
