my trunk has been soaked for the last 4 times its rained hard here. . . i cant tell where its coming from and can only guess that it could be the sunroof seals/drains. anybody else have this problem? its only wet on the trunk floor and under the rear shelf where the speakers are. im starting to get worried about my subwoofer back there in that MDF box.
question about sunroof seals. . .
i could be leaking from your tail lamp seals, or the trunk lid weatherstrip isnt sealing against the trunk lid. or the sunroof drain tubes are out of place and the water is getting in that way. just throwing out some ideas. good luck on the search and fix91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
