I parked my car next to a escort at work, and I noticed the seatbelt was automatic like the one in my 323. I took a closer look, the seat belt looked just like the ones in the Protege. Problem is there aren't that many 323s in the jy around my way. Does anyone know if a egt's seatbelts are the same as the 323s and Protege?
seat belt question
323 has a shorter wheelbase so i'd assume also shorter doors... so i'm betting youre gonna need 323 belts.
UNLESS you get manual seat belts from someone in canada, in which case 2-door escort ones should work just fine.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
well you still need the canadian trim pieces in order to have a nice clean install.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
wheel base...
its gonna have to be from a 323 most likelyEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
