Got a scuff in my paint after a run in with a montero. Chick swerved across 3 lanes of traffic to get into a turn lane and said she didn't even look. The car wasn't even hers, her car was in the shop from another accident.......ain't life grand? Anyway, not too bad on damage, she just kissed me. Ended up with scuffed paint and a broken plastic wheel well piece. Anyone know what kind of wax I could try and use to buff out the scuff in the finish. Didn't even reach the paint, just the clearcoat. That and does anyone know where I can buy another plastic piece and how much? Thanks a lot for the help again guys.
scuffed paint
okay depends on where you live, any car store should ahve the buff wax or touch up aint you require, a little elbow work adn you should be fine. I would reccomend Canadian Tire if there is one near you.
As far as teh plastic peice goes, what exactly is it? talk to your dealer or *gasp* an autosalvage yard, you could probably get one for 5 $.
It's the plastic piece that lines the wheel well to keep things from being flicked up into the engine. Thanks for the help, I'm in FL too if that matters.02' Protege ES sedan w/ 03 refresh package, loaded with everything minus sunroof, 5 speed manual, red neons under seats to match red lighting on guage cluster/center consol *you can't hug children with nuclear arms*
yeah as far as taht plastic peice goes, it shouldn't be to hard to get ahols of, I deffiantly think money wise a salvage yard is teh way to go. any mechanic or auto pro could reccomend a place to touch your car up, or may even do it for free if it's only a quick buff job on a scuff, depends on if your a regular.
Hmmm. It kinda sucks not being able to see how bad the scuff is but ....Mothers has a scratch remover and a three stage wax system that works pretty well. Your best bet is to use a orbital buffer to get better results. However, if that doesnt work you will have to use a high speed buffing method with a rubbing compound. NOTE: High speed can and will burn your paint if not used correctly. If it does come to that stage I would HIGHLY recomend a pro to do it. Unfortunately it would most likely be done at a bodyshop. Hopefully you know someone that knows how to do it and may give you a break in price. Good luck." Autobots are an error I intend to correct"
Reformated Alternate Mode:
Midnite Blue P5 ( 5-speed manual)
Painted calipers
Injen CAI
Custom exhaust
Tein lowering springs(finally installed)
scuffs and light scratches
Just a hint, the original toothpaste....not the gel.
Is one of the best"soft abrassives to use on paint.
Due to its contents,there is enough abrassive material to remove scuffs when applied in a moist hase....but won't harm your paint.
I learned this years ago with all my road bike tank scuffs.Since then i swear by it.kevin & karen liphard
ESSENTIAL SPEED, ontario. canada.
"when speed is Essential"
