Mine are the same way. I'm guessing get some trim-black paint from somewhere, mask away, and make it look good. you could probably take them off, if you take all the window trim off I suppose.
tape Them Off,quick Sand And Flat Black Rattle Can Them
All correct ways to paint them. Like Sarge said try SEM makes a trim-black that's nice and dries quick. In a tall white can, about $12-15. You know it's all about the prep, don't need to use primer just don't go gloss whatever you do.
just about every 323 ive seen have those corners like that, mine too. im going to be primering my entire car in a couple of weeks, and im just going to mask the stuff off and spray everything on the car.
