Has anyone here tried this yet? Ive obtained a cheap set of MSP seats and they are quite a bit different as far as the seat rails and mounting locations.
one of the front bolts is right where it needs to be which i am using as the base point the other front is about 2" too wide. The otter rear mount is close and can be made to work with a little cutting and the inner is completely different.
I knew this would not be a drop in affair nor simple im just curious if anyone has done this before and what their course of action was.
I did a search and it yielded no results worthwhile.
As it looks now, I should be able to gain at least an extra inch by swapping the outer rail mounts and having them re-welded since they will be facing the opposite direction. Doing this with elongating the holes slightly should give me enough room to get the front taken care of.
As for the rear, I think I can cut the metal return off the bottom of the rail to make it sit nice and flat for the outer mount but the inner is going to have to be something very creative. The way it is now I think I can bolt it to the exhaust hump in the floor but i'm concerned that it will not have the integrity to maintain seat position in the event of a collision.
