Originally posted by TheLastMarauder
question with my pw windows
i was going to make a how to on it when i did it but i 4got to take pics
go to a junk yard......
find a pro with all the power options
take the door pannel off and just start unbolting everything untill its all out......then under the dash there is a relay for the power locks....i forget what 1 it is but just look under you dash and see what 1's you have and pull the 1 out of the lx that you dont have.....then you gotta take the wireing harnes thats in the door out......DONT CUT IT......where it connects to the body of the car there is a plug....just unplug it.......the mirrors have 2 or 3 screws that hold them on, and you also need the switch in the dash (your car should already have the plug in it just no switch....then take it all and put it into your car.......oh and if you take the back power windows then you need the square windows(the sliders on the bottom is different) in the back doors (ya dont need the triangle ones)
hope that helps some..... if ya need help pm me or catch me on MSN
good luck
shaun91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
basically to sum this up evem more, go to a j/y and pull all 4 doors with their contents still in them.
lift up the carpet and pull every wire you see than runs on the floorboard. ther should be one wire that goes to both b pillars and connects under the dash.
install new doors and voila the easy way to get power windows.When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
lol yeah that works too.....the wire that goes under the carpet plugs in somewhere around the fuse box, i dont remember exactly where........it may take you a few hrs to get all the **** out of a jy car but its wwweeelllll worth it....91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
i pulled out a set of power accesories for cablemirc, believe me when i say life isn't fun, i averaged 90 minutes a door, to pull **** out.When you turn your car on... does it return the favor?
wow dude theres a lot of love between you 2
how hard is it to do/find that parts for the manual seatbelt convertion that cablemirc has done to his car?91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
