Howdy,
Trying to track down a power lock issue with my '94 LX -- they'll unlock, but don't lock in response to the driver's door lock.
Found an old thread with the opposite situation, which was apparently solved by a new relay.
I've gone so far as to test the door switch at the connector, and that seems to indicate the switch is fine.
I can hear the relay clicking while manipulating the driver's door lock, so it hasn't failed entirely, but it would still seem to be the logical suspect.
But, based on what I see in the service manual, versus what I see when I search for the part, I'm uncertain which is the correct part.
The service manual illustrations show a different, more complex plug, while this part is what comes up in searches, and on Rockauto's catalog.
Based on what I can see when I poke around under the dash, it is indeed the correct part, even though it doesn't conform to the service manual's drawings.
If I were to label the attached pic of the relays (from L to R):
1) black/white higher position
2) black/white
3) larger black
4) larger grey
Which one in the llneup is the suspect?
Looking for the wisdom and confirmation I'm not crazy.
A new twist emerged during this testing, being that the RR door lock has stopped actuating altogether, and is doesn't freely lock/unlock even manually. I'm wondering if the actuator died coincidentally, or something is binding up. Ugh.
Thanks for any guidance.
2) black/white
3) larger black
4) larger grey
