Hatchback window locks
    So my soon to be mine $400 hatchback has both rear windows missing the latches to close them and lock them. Is there a place to get them so I can seal up my ride?
    Tried junkyards? Check car-part.com if you can't find any locally.
    1990 Protege 4WD
    1 3 5
    2 4 R
      The problem of living in a rust free zone is that the sun destroys plastic and rubber parts.
      I'll check put that site, thanks.
        You ever find these? I should have an extra set in the next few months.
        1990 Protege 4WD
        1 3 5
        2 4 R
