how hard exactly is it to install, what are the parts i will need, and what wiring will i have to do?
installing an ac system into a 92 323 with no a/c system?
hmmmm... how technically inclined are you? because IMHO doing a turbo is easier. but you will need the compressor, condesnor, the hosing, and a few other parts, i'll go look those up, you will need to get someone licences to charge the system with the proper fluid. not R12When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
parts needed
Compressor
Condensor,
magnetic clutch
Reciever/drier
Refigerant pressure switch 1
refrgerent pressure switch 2
condensor fan
Cooling unit
A/C relay
Condensor fan realy
and piping
oh and a few wiring harnessesWhen you turn your car on... does it return the favor?
