After some time diagnosing the heating system the other day with the temperature gun, I found out that my radiator is partially clogged (temperature ranges from 170f to 70f at random places). But that is no reason for the heater not to blow hot air. Touching either of the heater hoses with the temperature control lever at full hot position revealed that both inlet and outlet hoses are cold. Which means that there's no coolant going in or out from the heater core. Blower works very good, and the flaps in the airbox works as they're supposed to.
Now, the Chilton manual I have mentions a heater control valve, the one that's supposedly is somewhere in the engine bay, before the inlet. But it doesn't show nor suggest a location. I'm hoping those with Mazda FSM can help me through illustration.
It's getting cold, and having to turn on the a/c to help de-frost the windshield on a 30 minutes one way daily trip sucks.
The idea is, once the heater control valve location is revealed, I'll by-pass the valve and see if the hoses and core are getting hot..
