hotwiring a 323 help.... !!!
    lol well here is the story,,, my key broke off in my igntion a long time ago so i was using a screwdriver to start it for a while ( untill i could get a new igntion) well then the rest of the igntion broke doing that as i knew it would just a matter of time... well then i was at work and my friend wired the car up on 3 toggle switches im not sure what he did exactly but basicly i had to toggles in my center consol., and one under the stearing wheel, one of them in the center consol woudl always stay on... then i would turn the one switch under the wheel and it would turn the car on accessory then hte other in the consol i would flip it up untill the car started and then i would put it back down right after to prevent ****ing the starter up.... well lastnight the switch under the wheel came undone on my way to work so the car turned off and i just twisted those two wires 2getehr, and then did the toggle thing to start it.. well i got to work took the two wires apaprt form under the hweel to turn the car off.., did the same thing to get 2 my friends house today... but when i went 2 leave my friends, i put hte wires 2getehr and the car didnt turn on accessory.... so i figured when i got outa the car i must not have seperated the wires enough so they where touching and the battery drained... well tried jumping it and nohting.. so i think when i got to my friends house when i disconnected the wires.. i pulled one of them lose form the ingtion loom itslef... can anyone tell me what wire is what... in the igntion area so that i know tomarrow when i go to pick it up.... or just how to hotwire it... lol thanks ..
    can you take some pictures of the problem??
      yeah man that is bad, if you can get pics that would help. if you where closer theres a few 323's down here with intacted ignitions in the j/y.
        Why are the keys for this specific model so fragile? I've gone through at least 6 in my first year of owning it. O_o
          lube teh locks and its less of an issue.
          Damn chad that sounds like a really bad problem. Hopefully you get it worked out.
          The two wires you speak of are hard to say what exactly w/o seeing them.
          bump for pics.
            yeah me too but i have been lucky enough not to break one off in the ignition though just the hatch where i had to take a dental pick to get it out.
            I Do not own a Mazda anymore!
              hey Chad, if you're still curious on how to hotwire your car, you will need the key to turn on your fuel pump and accessories unfortunately. i know when my ignition switch went, i spliced in on the relay on the passengers side and made a push button start, which i am still using today.
              also, what you can do to get your old key out, is take the paneling from behind
              the steering wheel, then start to disassemble the ingition switch, just be careful, once its taken apart, you should actually see your keep sitting there, so its as easy as pushing it out then replacing your key and ignition switch (if the switch is the problem) and if its not the switch, you can EASILY make a push button so you'll never have to worry about it.
              i cant take pics or tell you what wires to splice today tho, im working 9:30am-11:30pm today
              good luck
              JACK
                First off take the four screws that hold the column cover on the steering column, and remove the column cover all together... one screw on the back of the metal key switch holds the plastic ignition switch portion on it, unplug four connectors for that... go to a junk yard and pull a good unspliced one out and swap... you can leave the metal one alone as long as the wheel is unlocked.. just use a screwdriver to turn the plastic switch... less risk of having the battery getting drained because of wire splicing... just find some way for somebody not to pinch your car from ya...
                  Been there, done that...twice.
                    well i got teh car back today., just had to fix a wire... i will post pics of this mess in a few min.. hahaha its crazy
                      well here is my mess lol, the car runs thats all i care about, i will be getting a new igntion here shortly when i get money to go pickup my **** from mike_moss
                        damn d00d.... careful you dont short something out.
                          It may seem like an obvious question but why didn't you replace the swich in the first place instead of fuggin around with 3 different switchs seems retarded to me.
                          Pat.
                            i bought a new ignition, i just have to have a chance to make it to toronto to pick it up along with my spare BP
