What did you do to your BG today??
    Dropped some seafoam into the oil and fuel yesterday. Gettin all the gunk loose before I do an oil change.
    I also use my pro as a psuedo mobile toolbox. :p I had it parked in front of my Trans Am - Trunk open with tool box at the ready. I was installing a MSD HEI Ignition coil.
      I pulled all the carpet in my hatch and put in manual seatbelts. started it up and was gonna go hang out with people and realized that i didn't have any dash lights or tail lights or anything. so i gotta chase down a wire or a fuse or something.
        my car smokes yet another thing i need to replace
          Smoking is a nasty habit.
            Put in a new distro o-ring, cap, and rotor. The car is WAY MORE powerful now, I think my old stuff was defective. The change made a really noticeable difference in power. Then I did the fuel filter, fixed the window washers, installed the front strut tower bar, put in coolant, changed the oil and filter, put on the winter bleh radials.
              grounded it... car still feels the same to me
              passenger's side
              intake manifold
              distributor
              AFM
              transmission
              you think the wire close to the distributor is OK? it's not really touching it, it's more like a penny thickness away
                daisy chaining wires is less efficient than if each single ground wire run to the battery terminal..
                thats why grounding kits come with the mounting ring that goes directly on the terminal and all the grounding wires are attached to it. You can, however, fabricate your own bus plate and run all your grounds directly to it.
                theres some posts about it around here somewhere..
                Lookin good tho.
                DX BP swap/turbo build
                  well it's nice to know i'm finding this out now
                  so basically what i did was a waste of time and money? is it fixable? cuz all the wires are already cut to length, and it was expensive!
                    Word to your moms.
                    Sounds like a productive day.
                      Tried to put that little light above the ignition into my 323, didnt work, it gets power but no ground, is there a switch on the door or something that turns it on?
                      1990 EGT Turbo RIP
                      1995 EGT GTX RIP
                      1991 323 GTX swapped
                      2003.5 MSP
                        You need the subcomputer thingage from an LX
                          Oh, that makes sense, thanks
                          1990 EGT Turbo RIP
                          1995 EGT GTX RIP
                          2003.5 MSP
                            Well we had to smog gtxfamilia's car so we made a bp26 n/a. We just swapped exhaust manifolds, removed the fmic, capped the oil return and coolant supply lines, and swapped injectors. We left the Gtx intake manifold, rx7 turboII fuel pump, and msd 6btm ignition. It took us 4 hrs to swap everything including the exhaust. It runs perfect but we could only get 80mph out of 3rd gear on the fwy.
                            Kinda SLOW due to lower compression, but with the stage 3 clutch its overkill for the n/a. But still does a good burn out! We will swap everything back next week.
                            Also my car needs smog also so im gonna detune the motor and try and pass w/the turbo.
                            1990 Protege 4wd: BP05 forged internals, Mild ported head, GTR intake manifold, Gates racing timing belt, GTX transmission, Stage 3 clutch, 60trim T-3 turbo, Custom down pipe,3" Stainles exhaust, , Walbro fuel pump, RB-Performance fmic kit, HKS bov, Aurfa coilovers, F&R drilled slotted rotors, 16" BBS wrapped with Advan Novea tires, EDM glass headlights with HID's, Familia front and rear bumpers.
                            Boosted 1990 4WD
                            http://www.wihandyman.com/forum/showthread.php?t=32462
                              Well I installed new rotors and an amp for my front speakers! Carpet and new rear speaker mounts to go in later this week also Ventshades to go in tonight, I've been busy!
                              Looking for an Interplay Bumper!!!!
                                I installed new pads and rotors and vacuumed the interior
