Did a Burnout and for some god forsaken reason both tires where spinning and left dual marks ? Go figure , I have one of the most confused LX's around.
What did you do to your BG today??
Just got back from a new junkyard a friend told me about, which is about 15 miles from home. And finally found a complete LX. Come to think about it, there were only 4 other persons , and all the imports were pretty much complete. Due to a lack of funds, I had to settle with a set of electric mirrors, and the front rotors with calipers. (the rear ones are a pita to remove!). I'll probably primer them tonight and install them as well.
Originally posted by JhoMy fan relay was sticking on when my car got hot. I replaced the relay, and now the fan cycles properly.
there's a how to that shows how to loop the connector to eliminate the seatbelt beeping. the worn out seatbelt contacts within the center console will just beep whenever they want to, and that's what i had to get rid of.Chris
94 protege lx - gone and will be missed
2008 Mazda3 - recently acquired
"Life is tough, but it's tougher when you're Stupid."
-John Wayne
http://www.cardomain.com/ride/2978373
Originally posted by RonBurgundythere's a how to that shows how to loop the connector to eliminate the seatbelt beeping. the worn out seatbelt contacts within the center console will just beep whenever they want to, and that's what i had to get rid of.
here ya go. Jho found it for me when i mentioned it on a previous thread...
http://www.wihandyman.com/wil/howto/seatbeltlight/Chris
-John Wayne
Originally posted by RonBurgundyhere ya go. Jho found it for me when i mentioned it on a previous thread...
it's acting like a 'lean back' indicator. haha! it had to go...Chris
-John Wayne
Originally posted by DJ_PaRaNoIsEand the front rotors with calipers. (the rear ones are a pita to remove!).
Originally posted by MazKidThe rear calipers? Are you kidding? I just removed one on Tuesday at the junkyard...just a matter of removing the wheel, 2 mounting bolts, the parking brake cable, and cutting the brake line. I suck at mechanical stuff and I managed to do it in less than 3 minutes start to finish.
