10/30 is your best bet. lucas no. not in the engine. works nice in diffs. only additive i would use is tx7 (hard to find) otherwise get yourself some valvoline maxlife 1030. synthetic maxlife if you dont have oil leaks but with your bad burning id stick with conventional.
What did you do to your BG today??
how many miles i got 146000 and dont burn a drop that i can tell but i change my oil every 1500 so who knows.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by TRRCAdjusted my coilovers, but it still isn't low enough... something will have to be done! When I get things sorted out, I'll post some lowered pics. and BTW, I just hit 182,000, and my car burns about a quart of oil a month.2005 Mazda 3
Originally posted by BP18Protegechecked my oil to day to find out its full!! 163k and everytime i check the oil it's full.
gotta get around to putting the new filler neck/emis. tubes in by the fuel tank.
jdmpwrdford, do you leak oil or burn it?
I myself have used the lucas oil treatment, it is well worth it... I guess i would use the thicker oils in it, not 5w30. Then add the lucas so your oil level is full.
I dont know about oil consumption but I lose about a gallon of anti-freeze every mile.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Havent been on the site in a couple days, but my recent work, within the past week or so:
-Had the toe adjusted
-Both ball joints
-Left outer tie rod
-Drained the straight water I had in my cooling system today and replaced with 50/50 (car sat for a long time before I bought it, pure water cleans pretty well)
-Took for aftermarket 14" wheels off a car sitting in the back of ym lot at the shop. One of my hubcaps flew off one day and hit a car behind me lol. I figured I'd take the aftermarket wheels as anythings better than rocking steelies!
-Tyler
My car is lowered more than 4 inches, and my camber is still in spec.my car pwn's you
i know i didn't do it today, but i worked on taking the pin stripping off today. i have blisters on my hands, and am only 1/4 way done. here are the pics from when i washed it.
all the pics can be seen here.
Originally posted by bpt323Thats why your car will handle like **** in the corners JHOmy car pwn's you
Bring it on Cloud Dancing! My car handles like it's on rails.
Originally posted by deadly_sleeperi know i didn't do it today, but i worked on taking the pin stripping off today. i have blisters on my hands, and am only 1/4 way done. here are the pics from when i washed it.
Teh hottness!
JDM hottnessc+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Originally posted by JhoMy car handles like it's on rails.1993 Protege LX-Midnight's shadow SOLD
