well im focusing right now on getting it mechanically perfect or at least close to it. well the car is ugly right now. still missing teeth and all. but ill get there.
After work I put my car on the lift and found out what has been causing the clunk in my right rear. One of my ****ty old sway bar endlink bushings is missing. It probably fell apart and withered away.
Anyways, looks like a good time to upgrade the sway bar and bushings.
Any suggestions?
time for the zx2 hyper kit
yes, Replace your TTL's with MX3 ones which are longer & buy some hiem joints through me to use with the longer arms.
Hmmm tempting Ryan. But I'm tucking rubber in the rear, and I'm already a cunt hair off of the rolled quarters. I definitely can't go any wider with my stance.
Front Control Arm Bushings
Front 25mm and Rear 13mm Sway Bar and End Link Bushings
Rear Trailing Arm Bushings
Steering Rack Bushings
Transmission Shifter Stabilizer Bushings
edit:heres the thread i made when i did the work. page 4 has the bushing pics.
.......Then on the drive home, I had my cruise set at 69. I got pulled over doing 71 in a 55. Looks like someones off. Anyways I only got a written warning.
