does anyone know where i can find a Ignition switch wiring diagram. i find one site that gave me 1 of the plugs. the 1 with 4 wires in it. can anyone help me with the other plug that has 2 wires in it.
wiring diagrm help
What you have is a x-02 connector. The 2 blacks are for the ignition switch. They run from ignition switch to the x-02 connector you are talking about. then to the x-01 connector. Which im not sure but it shows it going to 80A fuse or relay. Then to the pos post on battery.
The Blue is your main ignition wire( should be thicker then the rest)
Now the rest im not sure but i will tell you what it shows in my book.
black red runs to wiper 20A fuse(i think in fuse box in kick panel)
Black white runs to radio 15A fuse
Should help a littleMx3 RS,BP-turbo
http://www.cardomain.com/ride/2628805
Black blue runs to starter interlock switch, inhibitor switch, cruise, ECU, and EC-AT control unit(thats for auto tranny)Mx3 RS,BP-turbo
