not on these exact pipes. but stock iron ones. for any car i guess.
anyway, cut the old factory pipes off an weld just slightly larger ones on the (bolt on piece?) and weld on inside, then grind and smooth. then when your at (circled blue section in pic) drill a hole for the o2 sensor and use a nut that has the same threading as your o2. and re-use the old hangers and fastners,(green selection)
if the pipes were slightly larger, (all the way to your muffler) this would increase performance. correct?
lets say you used this info just to make a turbo setup, and not to the muffler.
idk, lets say a geo metro?
