I was driving to work today and was waiting at the stop light then a plum of steam came out from under the hood. So I pulled over and it was coming from under the exhaust manifold. I'm assuming that the return line coming from the heater core re-circulating back towards the water pump, heh....
So my assumption that is the coolant bypass, is there a better way to re-route that around and away from the exhaust manifold?
I was thinking about pulling it off and cutting the pipe and buy a heavy duty rubber hose that can handle the pressure and heat from the local auto parts store including very good clamps. Re-route towards the radiator instead of passing the underside of the exhaust manifold.
Any opinions would be appreciated for a better route or its not a good idea...
I guess do to age and metal fatigue plus recently installed a new water pump, the pressure built up and the pipe decided to bust open on a bad day.
