by the back or the front? and what I need to clip off? Its so small damn it
how to remove fawking ECU yellow pins
do you want to remove them from the ecu or from the harness?
if its from the harness you pop up the flip part on the back, then use a small flat screwdriver from those tiny screwdriver kits, and you stuff it in the front, it'll work its way free.
If you want to remove the pins from teh ecu itself...I ahve no clue, I'd ahve to try
nickPosted By: Wheresthericego
The BP crank is made out of invincible.
Look carefully at the terminal in the harness...1 side of it you'll see a plastic flap hanging down to catch part of the terminal. This is the part you need to pry up to get the terminal out. Push the wire in, then pry the thing up, then pull the wire out. It's easy once you get the hang of it - having a set of Mazda terminal tools helps too.
1994 Protege BP-Turbo.....1994 Miata Supercharged.....2003 Protege5 stock DD.....1988 323 GT Turbo
On the road soon: 2003 Protege5 V6 swap
My vB Gallery - Full Information and Photos of My Mazdas
